Invisible coating that makes wood “fireproof”
Researchers at Nanyang Technological University have developed a coating that they say makes wood “fireproof’ while allowing the woodgrain to show through. The coating, about 75 microns thick, creates a flame barrier when activated by fire.
When heated by flame, a series of chemical reactions happen, causing the coating to become a char that expands to more than 30 times its original thickness. This char prevents the fire from combusting the wood underneath, as shown in an accredited lab test.
“Most timber or wooden panels only have a transparent coat that protects them from moisture, weather corrosion, termites or pests, and are not designed to withstand high heat. Thus, timber can still burn very quickly, especially if it is unprotected,” explained Assoc Prof Dasari, an expert in fire-retardant materials.
“In our coating, we used technology to lock certain compounds and interact with the resin. They will actively participate in the chemical reactions systematically when exposed to high heat, thus leading to the formation of char. This char was engineered to be extremely heat-resistant, insulating the wood underneath from the high heat.”
The innovation has a technology disclosure filed through NTUitive, NTU’s innovation and enterprise company, and the commercialization project was funded S$250,000 through the NTUitive Gap Fund.
NTU Vice President (Innovation and Entrepreneurship) Professor Louis Phee, described this innovation as a revolutionary step forward for the timber construction industry. “Leveraging on NTU’s strengths in materials sciences and engineering, this is an example of how fundamental research can be translated into commercial applications with high impact, given that the invisible coating enhances both safety and aesthetics in timber construction with few to no drawbacks,” Phee said. “Innovations like this are what NTU can offer to industry players who are keen to work with us to license, commercialize and adopt technologies that can be used to create unique products that will ensure competitiveness for Singapore in the global market.”
The NTU team is now in licensing talks with different companies. Venturer Timberwork is actively exploring the usage of this innovative coating to protect their mass-engineered timber elements in one of their current projects. Bolstering engineered timber’s resistance to fire is critical to expanding the uptake of this technology across more of the built environment, says Kevin Hill, Venturer’s managing director.
“At Venturer, like other stakeholders in the Mass timber construction sector, we believe more new projects will look at using this new coating technology if fire resistance can be improved. It has the potential to reduce cost and reliance on other more expensive solutions, such as using thicker timber to increase charring layers, or by encapsulating the timber with fireboards, which negates the beauty of this sustainable and productive building technology.”
Written by Larry Adams
Original article
This looks like an amazing technology if it’s scalable and inexpensive to apply. Thank you for sharing @Leo_Spunt!Are there any comparable approaches available in Europe or North America that are already being used? And if not, could this technology accelerate Mass Timber adoption?
@David_Stallcop, @Nic_Wilson, @ARNIE_DIDIER, @Jason_Thorne, @Oleksiy_Alex_Chygryn, @Pete_Kobelt, @Will_Leverett , @Steve_Marshall , @Will_Leverett , @Sung_Cho
Ditto! would be great to learn where this Chinese technology for MassTimber fall within the domestic and European solutions …
It doesn’t seem to me that there are other technologies being developed right now in Europe or North America. I wonder if this innovation will spark further research into the topic in the EU or NA.
Looks like an awesome development.
The interesting thing here is the wording. There is a big difference between fireproof and fire-resistant. Nothing is fireproof, if it is hot enough, hence lava, right.
So the question is which industry tests have been used? ASTM E84 Standard Test Method for Surface Burning is the industry norm for evaluating wood flame spread.
Then you have to determine if it impacts the strength of the wood, as some antioxidants can break down the wood cell structure. Also it needs to be tested in high heat and/or exterior weathering to determine if it cracks and peels off, which is often the case for coatings.
From the video it appears to me that it does not it penetrate into the wood and is just a surface intumescent. Fire-Retardant Treated Wood FRTW exists for structural applications, however, it is not designed to put out the fire but to allow occupants to egress out of the building.
We don’t use fire resistant wood for appearance products or CLT yet, but we should keep exploring these as options.
Thank you @Dallin_Brooks very informative!
Can you pls comment as to why fire resistant wood is used for neither appearance nor CLT? Is it a cost consideration? And if so, and it were introduced at scale, would the cost come down?
